Brother MFC Inkjet Printer prints Unidirectional mode only?
Smile
Europe EU
Hello,
My friend brought his MFC-5895 for repair. Same problem "No ink in the ink tubes". Quick FIX when you have 3D printed parts.
But his printer has this problem of only printing in Unidirectional mode, else the text is blurry.
All service manual adjustment done and make no difference.
timing strip is OK
See nozzle check is also out of alignment.
So looking for some help, seems like timing problem of the print head.
Smile
Europe EU
I wrote support to Brother.fi The support form but got reply from UK team???
Their resposnse is :
"Thank you for replying to us, It seems the issue is with the print head of the device.
The Serial & Model number provided shows that this machine is no longer within warranty.
Our U.K based office can repair the machine for you, subject to our fair condition policy (which means that the machine is in a repairable and undamaged condition). You will need to send the machine to the office at your own cost and we will inspect the unit before any work is carried out."
So not help at all. Usual promo stuff.
Smile
Europe EU
I just replaced the printhead on this printer, the print head is confirmed to be working OK on another printer. However installed in this problematic printer it has same problems of unidirectional printing only, same wrong nozzle check. This confirms that this is Brother Mainboard problem, anyone having same problem you need to replace the motherboard.
suwaidionlineuae
HP DesignJet T630 36 inch
If your Brother MFC Inkjet Printer prints in unidirectional mode only, check the print settings for bidirectional printing, update the driver, and ensure the paper type and quality settings are correct.
