bj i560...again
tpo
After washing in isopropyl alcohol of the print head, the normal green light is starting to twinkle in orange... any solution
TIA
Endmukbud
Indonesia
the light colour combination ??? what it is ???
each light combination translate to a specific error message ???
tpo
1 green 5 orange, 1 green...
Endmukbud
Indonesia
i can't read the service manual at the www. fixyourownprinter.com ( i think i550 is the same with 560, if i'm not wrong )
maybe you can read it
at reference --> manual --> canon section
cd187
I believe that the five orange lights blinking represent a printhead or printhead contact error/failure. Try removing the printhead and cleaning the copper foil contacts, using isopropyl alcohol, on the back of the printhead. While you are at it, visually inspect the contact pins on the printhead carriage after you remove the printhead. If any dirt, residue or debris is noticed, clean the contact pins as well. Then carefully reseat the printhead into the printhead carriage and close the locking lever. You may need to reseat the printhead more than once. Good luck.
