- Nov 3, 2004
- Location
- Bay Area CA
- CR-10, i560 ,MFC-7440N
I've been refilling all 5 of the tanks in my Canon i860 with excellent results...
Well, all of them except for the BCI-6bk which always has ink to the very top of the cartridge. I was actually getting bothered that I upgraded to the i860 from the i560 for the sole reason of this extra cartridge that didn't even seem to be used at all.
Every day or so I run a print head nozzle check pattern to see how all my little soldiers on the front line are doing and to give them a little excessive. To my dismay tonight the line that was suppose to be next to the BCI-6bk mark was non-existent. I was worried that my little BCI-6bk soldiers were sick, hurt, or maybe even worse... dead!
First step was to run a print head cleaning cycle. No dice, er... um... ink. I took the cart out and blew into the air intake maze / hole above the sponge (which usually works well to force ink out of the bottom outlet hole). No matter how much pressure I blew in, nothing came out.
This seemed very odd because the tank had been printing fine during nozzle checks for months. The air intake above the sponge couldn't be blocked because I would have had problems sooner.
I decided to pull the plug from the ink refill hole and just as I did the ink level dropped... fell... actually plummeted to the bottom of the tank. The thirsty little sponge sucked it dry before my very eyes!
I refilled the cart, sealed it up, blew on the air intake and little drops of ink came out the outlet whole. I put the tank back in, ran a cleaning cycle, and voiala... perfect nozzle check patters. All my little soldiers were back in action ready for my every command. "GO FORTH AND PRIIIIIIINT!"
So, now I'm more confused than I was before... actually I'm baffled!
BTW, all the cartridges in my printer are from alotofthings.com and are really easy to refill.
