Any differences between HP 95 and HP 97 cartridges?
LifeTakesVisa
Sorry, I'm a huge printer novice , I'm trying to pick a replacement color cartridge for my family's HP Officejet 6210xi, and there are two different compatible tri-color cartridges: HP 95 or 97.
As far as I can tell, the only difference is in the amount of ink each cartridge comes with - 95 comes with 7ml, 97 comes with 14 ml i think
Is there an actual printing quality difference between the HP 95 and the HP 97? In other words, I guess, is there any difference to the two other than they have different numbers and contain different amounts? If so, which one do you recommend (assuming price is irrelevant)?
Thanks
Manuchau
B.C. Canada
The printing will be identical. If you do a lot of printing, go with the larger 97. If you do very little colour, use the 95. 'Nuff said.
doctorwho52
Clarksville, TN USA
The only difference between HP 95 and 97 is tank size. Both use Vivera ink. Check your owner's manual before buying a 97 cartridge. Some printers can use both cartridges. Some use the 95 ONLY: A 97 will not work in these printers.
