A3 printer for freelance graphic designer (Epson 1290 EOL). Epson Stylus Photo 1500W?
JackBean
Epson 1290
Hi I have an Epson 1290 which has started to seriously clog and no amount of cleaning with glass cleaner, warm water, alcohol etc is getting rid of the clogs. I have tried 10+ times now.
So I have decided to buy a new printer. I use the printer mainly for presenting graphic designs to clients and printing holiday photos etc.
Epson 1290 level print quality is good enough for me so it seems Epson Stylus Photo 1500 would be the direct replacement/upgrade for it.
Some questions....
Q1- Epson 1290 had a roll feeder accessory....why does the newer 1500 not have it? Could I be able to adapt it to use on 1500? Is there a limit to the length I could print?
Q2- 1500 uses Clara ink. Can I buy after market cheaper Clara inks? What would I need to make it work? Any recommendation or advice?
Q3- Is there any other make or model you think I should buy instead?
Thank you very much.
JackBean
Epson 1290
No one?:old:hit
cls
Germany Hamburg
q1: the 1500w has no roll feed option but you
you can use the normal paperpath and create a custom paper size up to 111cm
additionaly with http://www.printfab.com/en/ printfab (which is some kind a low end RIP software)
which COULD allow you to do that and its FREE still end of 2014 (for beta purposes ) windows version
also http://www.fullbitsoft.net
has great results with his own rip software, downside is , each indiviuall printer requires and individuall license ~800 USD
it enabels the 1500W to print from roll also selective ink configuration instead of CYMK LC LM > CCYMMK (double cyan and magenta) for higher printspeed with loss of total gamut
I have the 1500W its a CRAZY machine, i print with pigmented ink with it
cls
Germany Hamburg
wutenprint sounds great but involves a great deal of learning and understanding, if someone has already a functional printing workflow you might have to renew amost every step of it including new icc profiles
Smile
Europe EU
JackBean
Epson 1290
Apostolos
Greece
1500w, M2170, G5040, X464
Thanks for the replies so far.So the printer seems decent enough.
Any views on cheaper after market inks similar to the default ones that I could buy in Europe?
I have been searching the forum and bit confused about the chipped ink part.
EDIT- Ok so this seems straight forward.
http://www.cityinkexpress.co.uk/ciss/epson/photo-1500w/photo-series/pigment-ink
http://www.youtube.com/watch?v=JJEl_dR0FcM
Is that ok ink + system?
I suppose it is ok, but keep in mind something @The Hat has said in another thread about ciss and pigment ink.
http://www.printerknowledge.com/threads/which-pigment-ink-for-epson-1500w.9323/page-2#post-76006
The best way according to those who know is a top feed CISS if we are going to use pigment ink.
I'm trying to find a top feed ciss in Europe so that i can order it with pigment ink, but all i can find is bottom feed. Bottom feed is considered very good for dye inks but cloggs easily with pigment inks.
If i find something i 'll write. If any one has any suggestions about top feed ciss in Europe market, please inform us. If i don't find anything, there is always the DIY solution, but i don't want to go there.
