3D Printer Project - Printed Toilet Seat Bumber / Spacer
Nifty
Administrator
Bay Area CA
CR-10, i560 ,MFC-7440N
So, I'll admit it... I LOVE having a bidet on a toilet! In fact, I've purchased about 7 of these SUPER cheap ones and given them to friends and even installed them for a few people... just to spread the true gospel! Many people (myself included) swear that it's the best $25 you could spend! (and the install only takes like 10 minutes)
I mean, look at the reviews! almost 6,500 4.5 stars!!! https://amzn.to/2MxH3SI
Anyway...
The only problem I had is with one of my toilets has a seat where after adding the bidet, the seat was raised higher, and not seating against the bowl. I had too much space between the bowl and the seat :(
I noticed the spacer / bumper / foot on the bottom of the seat (and space between the bumper and the bowl):
I pulled off the bumper and thought "I bet I could print a spacer for this!"
... and then remembered Chuck's video where he scanned a thing and imported it into tinkercad to model from!!!
See the first few minutes here:
You can see my scan of the bottom of my spacer here:
I edited it a bit in photoshop, converted it to black/white, and imported it into tinkercad:
2018-06-12 21_46_38-3D design toilet seat spacer _ Tinkercad _ https___www.tinkercad.com_.gif
Next I designed basic shapes into this model:
2018-06-12 21_47_02-3D design toilet seat spacer _ Tinkercad _ https___www.tinkercad.com_.gif
Which ended up like this:
2018-06-12 21_47_25-3D design toilet seat spacer _ Tinkercad _ https___www.tinkercad.com_.gif
My first few iterations were going to be replacing the existing gray bumper with this plastic one... which I did, and it worked pretty well.
... but, I liked the rubberized material of the existing bumper, so I took the shapes I used to create the holes, duplicated them, and made them "shapes", which ended up like this:
After a bunch of testing, tweaking, etc. (as seen below)...
... I ended up with perfection!!!
This was a very satisfying project!
@Nifty you are certainly getting full use of your 3D printer and I am doing much the same, because I can’t look at something without thinking I can make it better, I wonder when others will see just how handy and exciting these simple printers are...;)
Congratulations on another great project, this stuff is priceless, bring it on I say... :thumbsup
Hooray for the bidet but a cold spray? Brrr!
Great project, Nifty. Well done. :clap
Nifty
Administrator
Bay Area CA
You guys... :rolleyes:
They do make super fancy electronic heated seats, warm water, hot-air dry, bidets, but I actually like the simplicity of the manual cheap ones. I think everyone should spend the $25 and just try one out. Everyone I've purchased one for is quickly converted to a believer!
Regarding the print: Yeah, I really love finding ways to design and print myself out of problems!
What's funny is the old saying, "if all you have is a hammer, everything looks like a nail"... well, I sometimes feel like I'm always making up excuses / reasons to "fix" something with a 3D print! :D
Nifty
Administrator
Bay Area CA
Welp, I knew it was a question of "if" and not "when" my test prints for this project would break.
I had printed them with very little infill or wall strength to speed up the prototyping / printing process.
... and one just broke:
(you can see how little infill there was)
So, I printed a new version with 50% infill and 4 walls:
Should be MUCH stronger!
(took only about 10 minutes to print the replacement... 3D printers are so cool!!!)
I mostly found it faster to use high infill, up to 100% on most things that are going to get a bit of rough treatment, add up the time it takes to print something twice, especially when it time your trying to save and not the filament.
I can’t count the amount of times some of my projects broke in my hand with 30% infill...:hu
Nifty
Administrator
Bay Area CA
I don't think I've ever printed anything with 100% infill, but very few things I print require a lot of strength. Of course, I might change my tune if this thing breaks again ;)
