- May 29, 2007
- Location
- Ghent, Belgium
- Epson SC-P800,WF-7840,XP-15000
I think I measured that the minimum length should be 2 inches (measuring just the metal shaft of the needle), which is equivalent to"I get my Blunt needles from the following:
(push Pin/Thumb Tack thickness 22g)
CompuBiz Inkjet
http://216.219.159.185/tools.html#anchor29689
AlotOfThings.com
http://www.alotofthings.com/viartshop/products.php?category_id=58&page=2
Thank you for the links and information.jru said:Hello,
Beetlenut shared that he used a pushpin to make the hole to inject the ink.
I have used his method and think it works great.
Just push the pushpin to make the hole, then as you withdraw it, rotate it in a circular motion to expand the size of the hole at the point of entry. This allows the innermost edge of the hole to fit snugly around the needle as it is inserted.
Beetlenut had posted 2 places to buy the right size needles
in his post at http://www.nifty-stuff.com/forum/viewtopic.php?pid=14666#p14666
CompuBiz Inkjet
AlotOfThings.com
approx 50 mm.
Of course it's ok to be longer (I used 3.5" approx = 90 mm needle).
But 2 inches (50 mm) seemed like an ideal length to just reach into the reservoir chamber.
