- Dec 27, 2014
- Germany
- L805, WF2010, ET8550
Yes, I know their results, those together with the high prices were the reasons that I never tried that ink; but I got some sample ink from a photographer I met, and I just added such patches to my tests, against ink patches with the Epson D6 inks and DL inks which I printed somewhat earlier, so both inks were on the same sheet, same sun, same exposure time, same printer and driver settings.
I measure the lightness changes via the histograms so I can get some numbers even when you cannot differentiate the colors by eye, but I'm not able to recalculate them into something what Aardenburg is measuring. It could be as well that Lyson improved their inks after the bad results were published by Aardenburg. This all shows how tricky and difficult it is to get consistent and comparable results, you don't get anything from the ink suppliers and even less from the paper manufacturers about this characteristic, nothing in the data sheets, nothing by any shop what could be of help for a purchasing decision. With the tests of the photo papers I have several papers by Tecco in the test , these papers, by the same supplier , perform very good to very bad as well, but they don't tell you anyhting about this. I just try to find the 'best' ink and paper combinations, and if not the best overall on the market , then some combination which is close to it and at least much and visibly better than the average stuff. And my price vs. performance considerations may be different to other people's.
