- May 29, 2007
- Ghent, Belgium
- Epson SC-P800,WF-7840,XP-15000
Many forum members have enjoyed my formula to condition the sponge of Canon cartridges.
The formula is as follows:
-3 ml propylene glycol (or 2 % glycerol)
-20 ml isopropylalcohol
-distilled water up to 100 ml
The cleaning solution to free up clogged printheads is by adding 20-25 drops of concentrated ammonia to each 100 ml of cleaning solution.
Today I suffered from a tenacious clog in my Epson Pro 3800 in the magenta and cyan channel, caused probably by long term of non-usage and the very low humidity in my room because of the high heating since it is now freezing in Belgium. Even after 3 cleaning cycles the clog did not go away. In the past one cleaning cycle is enough to clean minor clogs. So today I folded a piece of towel paper into a nice thick and even strip and drenched it with my cleaning solution and put it under my printhead and let it soak for about 1 hour. After that I executed one cleaning cycle and...all the clogs are gone. Whow it works fantastic and the formula is very cheap to make.
