Help with printer purchase...
dwolf
I've filled so many Canon carts over the last 15 years. Even if the life of my cheap printers was shortened I am positive I am far ahead. My latest Canon does not print black anymore. A new head is ridiculous and over the years no technique I have ever tried fixed a problematic print head. With that said I am in the market for a new printer. I purchased a Canon Pixma TS6220... Turns out at the moment there is no way to reset the CLI-281. I did not open it yet but may return it for a printer that I can refill and reset or use a aftermarket cart that has ARC. I want to keep the purchase under $100. I also want to be able to use 80 Ib paper. All in One. My head is splitting with the research to pick a printer... Can you recommend one?
dwolf
WOW... the recommendations are overwhelming.
This is your fourth thread with your same request and the third begun by you this month November.
You have received advice. It may have not been what you wanted to hear but it was offered in good faith. I think you have tried and not been satisfied because what you ask seems like a unicorn except for finding a used machine or a one-off sweetheart of a deal. At least in a Canon AFAIK. Cannot advise on other manufacturers. Good luck.
- AIO
- 80 lbs card stock
- Refillable/Reset/ARC
- < $100
<No chance...
Edit:
dwolf
I spent hours to find what I had described and made some crazy assumption that people here would have already had that knowledge. TS6020
markusoft
Print Lurker
HP 8600
