50mm > 75mm roll adapters - Any idea where I can buy a couple?
guymark
Several
It is possible that these little things have a special name and as I do not know it, my searches on Ebay and elsewhere are not getting me very far.
If someone knows what I should search for, please enlighten me!
The printer I have can handle either 50mm rolls or 75mm rolls - but as it was second hand, did not come with all "extras" - notable for their absence was the "adaptors / sleeves" which allow you to convert the 50mm paper holders on the paper holder to 75mm.
If anyone knows where I could find a pair of these (or even what their correct name is), then I will carry on hunting.
I had toyed with the idea of just "bodging it" using umteen layers of tape but that seemed crude even by more less than elegant standards :)
I heard that SOME paper suppliers even used to include disposable ones in the ends of their 75mm rolls - but alas none of the paper suppliers I know of do that awesome thing.
Very many thanks
Mark
yes, some suppliers shipping paper on 3" rolls add an adapter to 2" with it, but I don't remember anymore how I got mine.
You just may create an intermediate fix - use a 2" core and add some layers of corrugated paper...
This is another case where a 3D printer comes in mighty handy, they would be a breeze to make.
Do you know anybody that has a 3D printer that could make them up for you...? ;)
guymark
Several
Thank you both.
I reckoned on being able to make a "get it going" solution but just wondered if Bloggs Paper Products supplied them for a few £ in which case Happy Days.
The idea of 3D printing is also spot on - and I do know someone who has a printer - but I think his reply would be "Sure, send me the file and I will print a couple out". Alas I wouldn't have the first clue as to how to design one from scratch to produce the file he needs in order to print it out.
I might see if (very temporarily), I can just use short section of of 2" cardboard tube from empty rolls and plonk it inside the 3" rolls with hot melt glue.
@guymark, How does this sound, if you send me the dimensions of your paper core and what size you want the new inset to be, I will make it up for you, and send you the STL file, so your friend can print for you... ;)
guymark
Several
Wow!
How Awesome is that - THANK YOU.
The size I HAVE at the moment is a 2 inch fitting on the spindle (until now all the rolls of paper I have bought have been 2 inch paper cores). the new paper rolls however are 3 inch cores.
So I need a "sleeve" with an internal size of 2 inches and an external size of 3 inches please.
Thank you very much indeed, that is awesomely kind of you :)
@guymark, Would this be suitable to fit your rolls, now is the time for adjustments if necessary...
Outer ring 95mm.
inner ring 75mm.
Centre ring 51mm.
New Core.jpg click to enlarge.
guymark
Several
I think that would be perfect as it should grip the cardboard tube well - yet be a slightly "easy" fit for the spindle mounted 2" fittings. My "3D friend" has already said he will be happy to print a couple for me - so as soon as the file is ready, that would be fantastic. Thank you very much indeed.
