1. Dismiss Notice
  2. Picture Of The Week (POW) Information and Submissions
    CLICK HERE!
    (if you are logged in, this notice can be dismissed using the "x" to the top right of the notice)
    Dismiss Notice
  3. Official PK Poll: Is there any future in refilling?
    CLICK HERE!
    Dismiss Notice
  4. PK Featured Thread: How to limit fading?
    CLICK HERE!
    Dismiss Notice
Waste ink almost full
Discussion in 'Canon InkJet Printers' started by alexandereci, May 15, 2007.
  1. May 15, 2007
    alexandereci
    alexandereci Printing Ninja
    Feb 12, 2006
    231
    99
    My Canon Ip1200 just flashed me a waste ink tank almost full message. I remember I wrecked my Ip1000 trying to fix this, I'd like to avoid this now if at all possible.
    Any ideas? Is there a way to reset this 'sensor' or something?
  2. May 15, 2007
    alexandereci
    Feb 12, 2006
    231
    99
    This is weird and annoying. Now I have to press the RESUME button BEFORE and AFTER printing. Is there a way to turn this "waste ink absorber almost full" message off?
  3. May 15, 2007
    fotofreek
    fotofreek Printer Master Moderator
    Nov 5, 2004
    1,811
    433
    San Francisco
    Although I have not had this problem, I have read that the printer will soon go into a mode that locks it up, and you will not be able to simply reset the full waste ink tank setting. All of these printers have codes that can be used to reset the waste ink counter to zero. You might google your particular printer waste ink code for this function. Someone on this forum may have the specific code for your printer. Several canon printer codes for resetting this function have been posted to this forum, but I don't know if they would work on this model.
  4. May 16, 2007
    alexandereci
    Feb 12, 2006
    231
    99
    Yes, that 'lock up' mode is what scares me. I think I'll have to bring this to a Canon repair center to reset the counter, wherever the darn thing is. What I don't like most is having to pay $$$ for something I'm not even sure if the guy in the store knows how to do properly.
    Found many 'procedures' to reset the waste ink counter, but none work for my printer, unfortunately. When I had my IP 1000, even that IP 1000 reset code didn't work. Grr!!!
  5. May 16, 2007
    alexandereci
    Feb 12, 2006
    231
    99
    Okay, I found a zip named "ip1600st" that unzips a folder named "iP1600ServiceToolV129" and starting up the .exe file gives me a program called "GeneralTool for T22240/32245/22234 Ver1.29" Apparently, this is from this site, specifically, this page.
    Just my bad luck I don't speak russian. Does anyone know how to use this tool? I presume other Canon service tools look just like this:
    [​IMG]
    If so, then can anyone clue me into what does what? I don't want to mess with 'unknown technology' that might fry my printer. Of course, the site has a little english translation, good enough to make me reset my waste in counter (woot!!), but what do the other functions do?
    Apparently, an IP 1200, IP 1600, and IP 2200 are considered the "same" printer by Canon.
  6. May 16, 2007
    InkMon
    InkMon Getting Fingers Dirty
    Apr 16, 2007
    93
    29
    Australia
    Copy the Russian text in the site at Babel fish, thats where most people go to translate stuff into their language
    Terry
  7. May 17, 2007
    jackson
    jackson Printer Guru
    Dec 14, 2005
    351
    121
    Ontario, Canada
  8. May 18, 2007
    alexandereci
    Feb 12, 2006
    231
    99
    Yes, the instructions are enough for me to do what I needed to do (clear waste ink tank message/counter), but now that I have this tool, I'm curious what the other function does. Anybody got an instruction manual for this thing, or for something like this?
  9. Jun 30, 2008
    hank freid news
    hank freid news Newbie to Printing
    Jun 30, 2008
    Like many others I have just received an error message telling me that my waste ink absorber is almost full on my Canon S900 inkjet printer. I found the suggestion from DaWeed B very useful but I wondered how difficult it is to clean the sponge pad. I can see this pad under the printer head. Do you need to remove it and wash it out? I have changed the printer head in the past which is very simple but imagine that removing the pad will be a very messy job. How easy is this? Is there much dismantling to be done? I am fairly good with with DIY jobs. I tested this pad using a cotton bud but it did not seem to be that full although the cotton bud did soak up some of the ink. It is suggested to remove the print head before resetting the printer code and I have read the suggested series of actions but when do you replace the print head, is it after action (6) Press power to set data. I did not need to reset the code after changing the Print Head but assume that I need to reset it after cleaning the sponge pad? Would appreciate any help you can give. Thank you.
  10. Jul 1, 2008
    headphonesman
    headphonesman Printer Guru
    Mar 18, 2006
    250
    109
    This is just a general reply based on the fact that i did this operation once on a Canon 6200.
    Before you start make sure you are in possession of the Waste Tank Full Re-set procedure for your printer , and that you understand the required steps. You can even go straight ahead and do it if you want. see next sentence.
    Please note it is possible to carry out this procedure without having done anything to physically cleaning or replacing the full ink pad. Some people just do a re-set and hope the pad will soak up a fair bit more before overflowing. But this carries a risk of spoiling the area underneath the printer, and needs constant monitoring.
    Yes there is a fair bit of dismantling to do to get at the large felt pad that occupies 50% of the floor pan area of the machine
    This involves taking apart machine case components and electrical assemblies.
    Yes it is very messy and should be done out of the house, several pairs of latex gloves and access to running water and a drain to wash into.
    Or you can look at what the pad is made out of ...and make a pattern replacement and fit that. Then go and clean the dirty one and keep for the next time it is needed.
    Yes it is possible to do yourself , and you get a good deal of satisfaction , but unless I really loved the printer and didnt want a newer model , I would avoid doing it , especially the dismantling and cleaning bit.
    Good Luck !
Share This Page
