Octupus inks
Palatino
Canon MG5150
Hi Borut,
I use Octopus inks in my MG5150 (using 525/526 cartridges). The quality is good, no need to ajust colors in printer driver, especialy for photos on glossy paper.
I recommend !
Borut
Slovenia
Canon Pro 10s
THX i just ordered set whit carts
OEM are abnormal expensive for that 11ml of inks
Borut
Slovenia
Canon Pro 10s
Ok,I just tested inks and carts Cartriges work super but becose in 95% prints are photos am gona stick to the OEM.
Photos are not so sharp as whit OEM inkcarts and they are lack of contrast there is also some color missmatch on faces.
I say this only for Canon Prixma MG7750 printer it uses also gray color.
But if you print only for you alone then Inks are good but not perfect.
The pigment black cart will stay in the printer,no need for text printing OEM inkcartrige.
Hi Borut, no 3rd party inks are going to be an exact match for OEM but they can be adjusted with the Manual Colour Adjustment, if you wish to get a more precise match, you need to use all the Octopus ink together otherwise you’ll never get a any colour balance..
Borut
Slovenia
Canon Pro 10s
I use all inks together.
is there some threat haw to adjust Colors?
Borut
Slovenia
Canon Pro 10s
Thx for link i'l tray that after empty OEM xl carts.
but i noticed that in color is no so much missmatch....... more is on detail sharpnes
hair,faces....
Borut
Slovenia
Canon Pro 10s
after for some days of use inks are ok.Il recomend it.
ozzy12
Print Lurker
prusa 3d
i didnt use it but read some reviews, mention that the Octopus ink has a high yield and can be refilled multiple times with good results. It is also cheaper than the OEM inks.
