- Feb 24, 2005
- Location
- North of Boston, USA
- Canon i9900 (plus 5 spares)
I have always noted that the first refill on a purged and thoroughly dried cart (> 6 months in my basement) will cause the ink to be immediately wicked into the sponges - all the way to the top. I recently needed to fill a complete set of 8 colors, and found that the dye black (IS from Mikling) did not want to wick into the sponges like all 7 of the other colors did. Banging the cart to move the sponge into position had no effect. Thinking that I just had a bad cart, another cart was tried with the same result. Blowing into the refill hole pushed the ink into the sponge (on both carts), and the carts tested normal for the drip test and the blowing into the air vent test. One of them is now in a printer, and it works normally. It remains to be seen how well these carts perform on subsequent refills.
If I was using the German refill method, there would have been no way to complete the 1st fill with this ink. I have never had the need to try Pharmacist's conditioning solution, but I can see that it would be necessary for certain inks when using the German refill method.
