ivanalbright
- Apr 3, 2010
Canon Pixma Pro 9000 MK II, using generic CLI-8 cartridges
A couple of days ago, I was printing out about 50 small pages of B&W text at a time. At one point, I replaced the black ink cartridge, then started up another 50 pages. I come back to see that the generic cartridge must have been faulty -- no black ink printed out for any of those pages. I figured okay, fine, that happens sometimes with these cheap / generic cartridges, so I popped in another new generic black cartridge. Usually this would be fine and it would start printing up normally again.
However, I am now getting the error "An ink tank error has occured. Open the printer's cover and replace the ink tank on which the ink lamp is off." However the ink lamp is not off--all cartridges are lit. Anyway, thinking I just had an unlucky second defective cartridge, I put in another black cartridge. Same problem. I have now tried over 6 different black cartridges, from 3 different generic sellers/brands. All are giving me the above error / printer status shows as "an ink tank cannot be recognized."
At one point, the error seemed fixed after I had powered off the printer for a while, and I was able to print off about 100 more pages. However then it returned as that black cartridge became empty and I can't get it to go away.
What I've tried:
Verified the black is causing the problem by putting in the ink tanks one at a time to check for the error
6+ new black cartridges, from several different sources (to verify its not just a defective batch of cartridges)--all causing the error
Cleaned the chip contacts on the printhead assembly with isoprobyl alcohol and a q-tip
Powered off printer (unplugged) for 5 minutes, 30 minutes, and a day
Removed printer from windows "Devices and Printers" area so it would reinstall itself
Any thoughts on where to go from here? My only thought is that somehow the contacts on printhead assembly are shorted or damaged, though I cleaned them carefully (with the power off) and they do not appear to be damaged. Thanks for any help!
edit: I should add that I have two of these printers and I have tested some of these cartridges with the other (working) printer, and they work fine there...
Basically, what I think happened is something went wrong with the chip contacts on the printhead assembly after printing for a bit with a bad cartridge, so it now isn't properly accepting cartridges in the black ink slot. Is there any way to reset that (or something along those lines?)
What I've tried:
