ANY inkjet print-firmware updates...
turbguy
Laramie, Wyoming
Canon i960, Canon i9900
It appears that the OEM's have discovered a way of BLOCKING ACCESS to service modes via firmware updates.
My recommendations, if your printer works for you, DISABLE/IGNORE/DO NOT PERMIT firmware updates!
As the printer's behaviour is determined in firmware, I think it is a very good advice only to update the firmware if absolutely needed.
I did a forum search on "canon service mode" I checked a lot of the hits and I noticed that some of the printers that couldn't enter service mode by the user were of the PGI-x50/CLI-x51 generation. There were no reports of any of these printers successfully entering service mode.
A special case is the iP7250 printer that according to druckerchannel.de can enter service mode, but will not do so for forum members, see this and this. Are there different revisions of the iP7250 and its firmware?
There have been some guesses to why newer Canon printers can no longer enter service mode by the user. See this thread by @anwar qais . The MG5540 is of the PGI-x50/CLI-x51 generation. In the first post a service tool v 4410 is asked for and in this post locking and unlocking of service mode is mentioned.
I have a Canon MG5550 that I tried to get to enter service mode. My first attempt was with the method that works for most PGI-x25/CLI-x26 printers with pressing the Stop/Resume button five times. The printer behaved normally with alternating lighting the power button and the warning light, and the LCD display turned white with no text. But the service tool did not work. I don't remember if the buttons were greyed out or there was an error message. If I try to enter service mode now, the printer either turns on normally or gets totally unresponsive with only the warning light on and doesn't respond to pressing the on/off button. Only disconnecting the the printer from the mains and waiting for maybe half a minute (for a capacitor in the power supply to discharge?) will revive the printer.
I think this confirms the locking of service mode by a wrong procedure and/or wrong version of the service tool as described by anwar qais.
I wonder if the newest versions of the Canon Pro printers can still enter service mode by the user, or they also have been blocked by needing a new procedure/service tool?
I also would like to see if some of the Pro printer can still enter Service Mode, and if the answer is no then did they upgrade their firmware or not..
This introduction would have started to take effect by late Sept-13, so any Firmware versions launched after that date would probably have this bug built into it, I still can’t get it confirmed if the print driver could possibility write to the EPROM chip itself..
...This introduction would have started to take effect by late Sept-13, so any Firmware versions launched after that date would probably have this bug built into it...
This makes sense. Druckerchannel.de tested the iP7250 in Nov. 2012. The absorber change article for this printer is from Feb. 2014 but it could possibly be the printer from 2012 that was used for the making of the article.
