- Apr 19, 2007
- USA
- Canon MB5120, Pencil
I think this may be the culprit for Win10 not installing the printer using its native drivers. According to the posts above, the printer must not be previously installed, turned on, or even be plugged into your motherboard when you first install on Win10. I think this is the way Canon wants an install done with its printers that I have seen, though I haven't seen them all.iP1900 printer attached and switched on, while WIN10 was set up and installed the drivers for three attached printers.
Turn off the printer, unplug the printer from your computer, uninstall the printer from your computer, reboot your computer and try the install again as per above.
