HP 6100 CISS priming the cartridges
ttgfish
hp 6100
I am having difficulty priming the line/cartridges for my HP 6100 CISS. I have tried to pull the ink through with a syringe through the plug and through the the hole where the ink comes out. But the air comes right back in. None of the videos online match the cartridge I use.
Do I stick the syringe in without the needle into to ink port? Or use the needle?
Confused.
ttgfish
hp 6100
It's printing OK, but I have air in the lines except the black. will it be a problem long term?
Any advice appreciated
Hi @ttgfish and welcome, I am surprised you didn’t get at least one reply to your questions.
I have not used a CISS for the last 5 years, plus I haven’t got a clue about an HP CISS, I would reckon you can use your syringe without the needle in the ink outlet port or just lower the carts one by one below the ink reservoir and allow the ink to flow back into the carts again till full.
You can catch the excess ink in a small container and put it back into the reservoir later if you wish, when you reinstall the carts again make sure that the ink reservoir bottles are level with the printer (Same height) and you secure the tubing properly before turning on the printer..
ttgfish
hp 6100
Thank you! I will try the lowering of the cartridges and see what happens. I really appreciate the help. I will report back how it works out.
ttgfish
hp 6100
I tried the syringe in the outlet port, but it just would not fit and I was afraid I might break it.
I tried the gravity approach and it worked at first, but then after a short time the air bubbles appeared at the junction of the tube and the cartridge again. The funny thing is that the computer seems to be printing fine despite the air.
Thanks to you "the hat" for your time and advice!
ttgfish
hp 6100
Well that did not last. Still have air in the lines, except the black. Now no color printing.
I did the gravity feed but once the cartridge is back in the air is back in. I also held the cartridge below the reservoir and drew ink through the fill plug with the syringe and while it was dripping out I replugged the hole. Still air...
Frustrating.
I wonder if there is a special attachment for the syringe to extract through the port? I'm going to look into that.
ttgfish
hp 6100
Im also wondering if I should have plugged the air intake instead of having that open? I had both open
If you do not have the CISS tubing secure enough while operating the printer it has a tendency to move around causing the cartridges to shake in the print head and this allows air to get in by way of the ink outlets, refillable cartridges maybe be a more reliable option..
ttgfish
hp 6100
I see what you are saying, but the air returns as soon as they are back in place prior to use.
Refillable cartridges would be simpler I suppose, but I want to figure this out. A challenge you know. :)
I ordered some adapters to be able to use the ink port to draw the ink out, so we will see.
Weird thing is the black ink works perfectly.
