Epson R2000 resetter for R2000 refillables
jtoolman
United States
All of them! LOL
All I have to tell you is that I only did one cart from a set of unused, filled and new refillables. It turned green. I will do the whole set tonight.
Then I reset two of my OEM that are presently loaded onto my R2000 which were about 75% empty and they turned green and upon reinsertion they showed up as FULL.
Joe
Thanks: just to be sure all refillables can be reset, before purchasing one of this resetter.
jtoolman
United States
All of them! LOL
The box says this on it:
"Chip Resetter for use with Original and Compatible EPST1590 - T1599 chips/EPS R2000 Printer"
The resetter is Blue!
I just reset a whole set of Carts From PC that I still have unused and pre filled. All reset to GREEN! I have not put them on my R2000 yet as I actually have an OEM set still in use and do not want to remove it till I have to. But I am 100% they will register as full by the driver.
Joe
Hi Joe,
Many thanks: could you give me the link of the seller of this resetter. I am interested in buying the one you have now. Edit: I already see you gave me the link of the resetter priced at $ 18.88. I just ordered one.
Ok just received the same resetter the one jtoolman has, but it is resetting is very difficult and only red was successfully reset. The original cartridges can be reset immediately.
jtoolman
United States
All of them! LOL
I will test it against a complete set of refillables for PC and report back!
Joe
jtoolman
United States
All of them! LOL
Ok I just reset ( Steady Green Light ) a full set of refillables purchased from PrecisionColors quite a while ago. They feature the "short out" the two round terminals to reset chip!
I also tested it on another two sets of different origin as well as a set of so called " Push Button to reset " carts fro China that I featured on one of my early videos.
So this resetter can reset all my R2000 carts, refillable or OEM.
Joe
Yes I can also reset them to green, but when inserted they stay the same except for red....
jtoolman
United States
All of them! LOL
AHHHH! I have not done that yet. The OEM ones do reset and display full. Guess this will not work with the battery resettable chips.
Joe
Hi Joe,
You can give it a try and see if they are reset properly. If so I might order the same cartridges you have. It could be your older version carts can be reset.
