- Apr 19, 2007
- USA
- Canon MB5120, Pencil
We cannot make that determination yet, though you may be correct. Canon print heads require liquid (ink) to keep cool during printing, otherwise they may burnout nozzles and you will have streaks of no ink on the printed paper. Ink clogs from dye-based inks (water-based) can be unclogged using a liquid such as ink itself or water or mixtures of different solvents and lots of patience. Until you provide more information we cannot know or advise further. Post a nozzle check. If you need instructions on obtaining a nozzle check or posting in the thread then ask. Someone will help.I think that the Canon's print head is beyond help and is clogged from lack of use
Concerning regularly printing something to keep from clogs... it isn't difficult or time consuming. All you need to do is print something that uses ink from all the ink cartridges, such as a nozzle check, once every week. I have gone longer than a week, but the general recommendation on the forum is once a week. Printing a nozzle check takes seconds once the printer is booted up and can provide early warning of a problem as well as help diagnosing the cause of a problem.
