- Thread starter
- #21
- Jan 18, 2010
- Residing in Wicklow Ireland
I was testing a new ink when these problems came to light so I knew I was risking the print head if things went pear shape so I was watching the print output like a hawk and stopped the printer once any of the colours started to fade or stopped altogether.
I keep getting failure on the yellow first then later the cyan started but both colours would always return when I ran a purge cycle, the magenta and black never suffered from any issues and always printed perfectly.
Later the yellow totally refused to print and the heads look like they were damaged (burned out), despite purging and external soaking and cleaning the nozzle print looked shot to pieces in fact it was worse than the magenta is currently, now it's back 100% again !
The magenta on the other hand just failed instantly no warning, that was much later dough, it was there one second and gone the next and I actually taught I could get it back functioning properly as well.
Every nozzle print from the magenta from that moment on was exactly the same and I knew it had gone beyond saving and so I decided to dismantle the heads to see if I could cure the disappearing cyan issue. (Curiosity)
The cyan is now back on I.S. ink as is all the other colours, but now the cyan heads would cease to print almost instantly just like the magenta did, but if left for 15 minutes would print normally, like nothing had happened and without the need for a purge cycle ?
The test inks on the other hand were fading out by 50 or 60% and would still continue to visually print but needed a purge cycle to bring them back to 100%, some difference.
I may never get to the bottom of this strange behaviour but I do hope I never come across it again, but these Canon print heads don’t half know how to throw a curved ball..
